[GRASS5] Re: [GRASSLIST:8931] db.copy fails with DBMI driver error
Kirk R. Wythers kwythers at umn.edu
Fri Nov 11 12:53:33 EST 2005
On Nov 10, 2005, at 3:55 PM, Jed O. Kaplan wrote:
> Kirk,
> I had success by specifying the complete path to the DBF database
> in the from_database= argument instead of ./ as in the example in
> the man pages.
Jed,
That solved my troubles too.
I have noticed that GRASS seems to be very picky about using explicit
paths to data directories (at least on a Mac). For example I often
have problems if I use the short cut (~/) to refer to my home
directory. I can't think of specific commands off the top of my head
right now, but I was wondering if anyone could confirm this to be an
issue on Linux machines as well?
Kirk
> GRASS 6.1.cvs (engadin-swissgrid):~ > db.copy from_driver=dbf
> from_database='/Users/jkaplan/Documents/grass/engadin-swissgrid/
> PERMANENT/dbf/' from_table=mapcodes2 to_driver=pg
> to_database="host=localhost,dbname=engadin" to_table=mapcodes3
> Seems to work!
> Cheers,
> Jed
> On 10 Nov 2005, at 20:16, Kirk R. Wythers wrote:
>>> from_database=./ from_table=mapcodes2 to_driver=pg
>>> to_database="host=localhost,dbname=engadin" to_table=mapcodes2
>>> DBMI-DBF driver error:
>>> Table 'mapcodes2' doesn't exist.
>> Did you try creating the table 'mapcodes' in postgres first before
>> copying from dbf? Does anyone know if this is a required step?
>> Kirk
>>> Error in db_open_select_cursor()
