[GRASS5] Re: [GRASSLIST:9006] Re: db.copy fails with DBMI driver error
Fri Nov 11 19:17:36 EST 2005
Kirk R. Wythers wrote:
> I have noticed that GRASS seems to be very picky about using explicit
> paths to data directories (at least on a Mac). For example I often
> have problems if I use the short cut (~/) to refer to my home
> directory. I can't think of specific commands off the top of my head
> right now, but I was wondering if anyone could confirm this to be an
> issue on Linux machines as well?
The ~ syntax is implemented by the shell, and only works when you are
typing commands into a shell or in shell scripts. It won't work
elsewhere (e.g. within d.m).
