[GRASS5] Re: [GRASSGUI] Re: More GRASS GUI thoughts...
Radim Blazek
radim.blazek at gmail.com
Tue Nov 15 03:52:04 EST 2005
On 11/15/05, Michael Barton <michael.barton at asu.edu> wrote:
> I like the tabbed idea except that a nice
> thing about having multiple monitors is so that you can compare them side
> beside too. So maybe if the tabs were to tear off? This could be very nice.
I agree that the possibility to easily compare more maps is important
but is the need permanent during the session? My experience is
that I need to compare more maps only from time to time.
Multiple windows are also necessity for rectification (4 windows).
So the tabs which can become windows seems to be possible solution.
The question is what the monitors should share -
- list of layers ?
- current extent ?
Sometimes you need the same extent sometimes the same layers
and divverent extent (region).
Radim
