[GRASS5] SQL support/DB backends
Markus Neteler
neteler at itc.it
Tue Nov 15 07:45:01 EST 2005
Hi Daniel, all
I have polished the examples (CSS) of
lib/db/sqlp/description.html
and was thinking about the limitations stated there.
Am I wrong that the limitations only apply to the
DBF driver? Once I use Postgresql etc, shouldn't I
get full SQL support such as provided by the DB backend?
If so, we should modify above page. If not so, we
should also clarify it :-)
Markus
