[GRASS5] GRASS GUI
Joel Peter William Pitt
pittj2 at lincoln.ac.nz
Tue Nov 15 17:53:05 EST 2005
Wolf Bergenheim wrote:
>On 11/15/2005 11:27 PM, Joel Peter William Pitt wrote:
>>Regarding comments on interface: One thing that I would love to see is a
>>specific GRASS shell, so when I'm typing in map parameters to a command
>>I can use autocompletion. In the same manner that bash allows you to
>>complete directories and filenames with tab, or shows you a list of
>>possible alternatives if more than one completion exists.
>The cool thing about using your own shell is that you have the same
>aliases etc. And most modern shells support autocompletion
>configuration. I know bash and tcsh atleas does it. On windows, if the
>shell is cmd, then defenately I think that a grass shell would be
>better. If we are going to develop a grass shell, then I'm defenately
>interested in doing it (:
>Check out http://www.sorokine.info/grass-complete/ for bash and tcsh
>completion. I haven't tried it yet, but I suppose it will work (;
Cool thanks!
This kind of thing should definately be made more prominent or
integrated into the GRASS distribution.
Joel Pitt, Room B534
Bio-Protection & Ecology Division
PO Box 84
Lincoln University 8150
New Zealand
