[GRASS5] Wish: category label support in v.to.rast
Maciek Sieczka
werchowyna at epf.pl
Sun Nov 20 15:42:07 EST 2005
On nie, 2005-11-20 at 20:35 +0100, Markus Neteler wrote:
> Hi,
> it would be nice to have implemented the category label transfer
> in vector/v.to.rast/support.c (G_set_cat() such as in r.buffer).
> Eg., converting the Spearfish 'fields' vector map should
> not only transfer the category numbers, but also the
> category labels to the raster map (maybe with additional
> column parameter to select the column to be written out
> as raster label).
> Most pieces seem to be there already.
Does my whish cover your or do you mean something more/else?
https://intevation.de/rt/webrt?serial_num=3045&display=History
Maciek
W polskim Internecie s± setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.epf.pl/
