[GRASS5] Wish: category label support in v.to.rast
Markus Neteler neteler at itc.it
Mon Nov 21 07:16:18 EST 2005
On Sun, Nov 20, 2005 at 09:42:07PM +0100, Maciek Sieczka wrote:
> On nie, 2005-11-20 at 20:35 +0100, Markus Neteler wrote:
> > Hi,
> > it would be nice to have implemented the category label transfer
> > in vector/v.to.rast/support.c (G_set_cat() such as in r.buffer).
> > Eg., converting the Spearfish 'fields' vector map should
> > not only transfer the category numbers, but also the
> > category labels to the raster map (maybe with additional
> > column parameter to select the column to be written out
> > as raster label).
> > Most pieces seem to be there already.
> Does my whish cover your or do you mean something more/else?
> https://intevation.de/rt/webrt?serial_num=3045&display=History
Only the labels remain, the cats are already written.
Markus
