[GRASS5] v.patch table
Martin Landa
landa.martin at gmail.com
Mon Nov 21 13:40:46 EST 2005
Hi Radim,
2005/11/21, Radim Blazek <radim.blazek at gmail.com>:
> I didn't have much time, look at it and if you believe
> that your patch is better we can use your version.
> Do you support all layers?
no, I do not really believe in it;-) I will try to modify the current
v.patch to add:
* support of 3D vector map layers
* multi-layer
* different structure of tables...
But, if you have time to do it, it will be really better - I am still
programmer beginner;-)
Best regards, Martin
> Radim
> On 11/21/05, Martin Landa <landa.martin at gmail.com> wrote:
> > Hi,
> > > I added table support (-e flag) to v.patch. It works
> > > only for layer 1 and tables must have the same
> > > structure: column names, types in the same order.
> > Currently I am working on it too:-( I have also added support of 3D
> > vector maps to v.patch. I wanted to send the patch to the list
> > tomorrow...
> > Martin
> > > Radim
> > > _______________________________________________
> > > grass5 mailing list
> > > grass5 at grass.itc.it
> > > http://grass.itc.it/mailman/listinfo/grass5
