[GRASS5] v.patch table
Radim Blazek
radim.blazek at gmail.com
Tue Nov 22 04:26:46 EST 2005
On 11/21/05, Martin Landa <landa.martin at gmail.com> wrote:
> Hi Radim,
> 2005/11/21, Radim Blazek <radim.blazek at gmail.com>:
> > I didn't have much time, look at it and if you believe
> > that your patch is better we can use your version.
> > Do you support all layers?
> no, I do not really believe in it;-) I will try to modify the current
> v.patch to add:
> * support of 3D vector map layers
> * multi-layer
> * different structure of tables...
How do you want to support different table structures?
> But, if you have time to do it, it will be really better - I am still
> programmer beginner;-)
No, I don't have time, I only needed that for my project.
Radim
