[GRASS5] timeseries: null file, r3
Joel Peter William Pitt
pittj2 at lincoln.ac.nz
Mon Nov 21 16:49:08 EST 2005
Hi there,
I need to store many thousands of maps for different model simulation
runs as each has at least 25 maps in a timeseries.
Currently running 100 replications of a 25 year model on a 2000x2000
region results in about 2.1 gig.
This on its own is okay, but I need to run sensitivity analyses on a
range of parameters, meaning each value I test for a parameter gives a
location of 2.1 gig!
Checking out the actual data files however shows that the cell files are
only about 60k each. The problem is the uncompressed null bitmasks that
are 700k each. Now, I can explicitly remove the null bitmask using
"r.null -r", but I was wondering if the null mask will just get
automatically created next time I run a GRASS command? Also, I'm under
the impression that if there is no null bitmask then values equal to 0
in the cell file are interpreted as nulls, is this right? Is there
anyway to specify NOT creating a null mask when creating a map?
A while back I suggested using 3d rasters to store timeseries, but I got
the impression at the time it wasn't very far developed and I knew
little about GRASS then. Does anyone who knows more about the r3 design
know if storing a timeseries in this way would be more space efficient?
The timeseries is a sequence of snapshots of a growing region, so for
the most part a region in a map at time t+1 will encompass the region in
a map at time t.
Thanks,
Joel
Joel Pitt, Room B534
Bio-Protection & Ecology Division
PO Box 84
Lincoln University 8150
New Zealand
