[GRASS5] timeseries: null file, r3
Glynn Clements
glynn at gclements.plus.com
Wed Nov 23 12:54:12 EST 2005
Joel Peter William Pitt wrote:
> I need to store many thousands of maps for different model simulation
> runs as each has at least 25 maps in a timeseries.
> Currently running 100 replications of a 25 year model on a 2000x2000
> region results in about 2.1 gig.
> This on its own is okay, but I need to run sensitivity analyses on a
> range of parameters, meaning each value I test for a parameter gives a
> location of 2.1 gig!
> Checking out the actual data files however shows that the cell files are
> only about 60k each. The problem is the uncompressed null bitmasks that
> are 700k each. Now, I can explicitly remove the null bitmask using
> "r.null -r", but I was wondering if the null mask will just get
> automatically created next time I run a GRASS command?
The null file is created when the map is created, or via r.null.
> Also, I'm under the impression that if there is no null bitmask then
> values equal to 0 in the cell file are interpreted as nulls, is this
> right?
For integer maps, yes. If a FP map doesn't have a null bitmap, all
cells are valid.
This is for compatibility with 4.3, which didn't have null bitmaps. It
didn't have FP maps either, so compatibility isn't an issue there.
This behaviour could easily be removed; see the following code in
get_null_value_row_nomask() in lib/gis/get_row.c:
if (read_null_bits(null_fd, fcb->null_work_buf,
i+fcb->min_null_row, fcb->cellhd.cols, fd) < 0)
if (fcb->map_type == CELL_TYPE)
If can't read null row, assume that all map 0's are nulls
use allocated G__.mask_buf to read map row */
get_map_row_nomask(fd, (void *) G__.mask_buf, i+fcb->min_null_row,
CELL_TYPE);
for (j = 0; j < G__.window.cols; j++)
if (G__.mask_buf[j] == 0)
flags[j] = 1;
else
flags[j] = 0;
else /* fp map */
/* if can't read null row, assume that all data is valid */
G_zero(flags, sizeof(char) * G__.window.cols);
/* the flags row is ready now */
} /*if no null file */
To disable the behaviour, replace the above block with:
4.3 is old enough that we could probably just remove that behaviour
altogether. It just requires anyone using maps which were created
using 4.3 to add a null bitmap with r.null.
> Is there anyway to specify NOT creating a null mask when creating a
> map?
No.
