[GRASS5] xganim and motif requirement
Helena Mitasova
hmitaso at unity.ncsu.edu
Tue Nov 22 15:03:10 EST 2005
I use xganim a lot to check the results of simulations that produce
time series of rasters and to preview
the rasters before doing more complex animations using file sequencing
tool in nviz. As far as I know
there is no other command that would produce quick simultaneous
animations of multiple raster series
(r.out.mpeg currently doesn't come anywhere close to the convenience of
xganim, and you can do only one series).
BUT I would love to see the requirement for Motif/Lesstif go away, so
if anybody can replace xganim with
a module with the same (or better) functionality without motif that
would be great.
The module comes from times when motif was used for GRASS GUI (just
another one that is not around anymore)
and nviz had motif-based interface too.
Helena
On Nov 22, 2005, at 12:58 PM, William Kyngesburye wrote:
> I was recently thinking about various GRASS requirements, what with
> all the GUI discussion. And, I saw Markus' comment on the users list
> that r3.showdspf funtionality is in NVIZ. One other one I'm wondering
> about - xganim.
> This is the only thing in GRASS (that I can see) that requires
> Motif/Lesstif. On Mac OS X at least, this is the only reason for
> installing mo/lesstif, as everything else is TclTk/X11/GL.
> So, could xganim be changed to not use motif? Or, like r3.showdspf,
> is the funtionality included elsewhere now so it's not even needed. I
> see that NVIZ has some animation capabilities, but they look quite
> different than simply animating a series of rasters. Maybe with the
> right options it could do the same?
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> "Time is an illusion - lunchtime doubly so."
> - Ford Prefect
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Helena Mitasova
Dept. of Marine, Earth and Atm. Sciences
1125 Jordan Hall, NCSU Box 8208,
Raleigh NC 27695
http://skagit.meas.ncsu.edu/~helena/
