[GRASS5] [GRASS] bug in surf panel in NVIZ
Stéphane Bidet
stephane.bidet at tremplin-utc.net
Wed Nov 23 00:09:12 EST 2005
I think there was a bug in NVIZ when adding a surface in the "surf" panel.
I'm working with grass-6.0.1 compiled from the source available on the
GRASS web site, and the data set "spearfish60".
The tests have been made on a debian system and a slackware system.
I first launch GRASS with the "elevation.dem" map available in the data
set.
After adding surface like "geology" from the "surf" panel, it seems that
when I press the "RESET" button on the main panel the value for the "exag"
and "height" are not the right one (exag=100 and height=96, the expected
values are exag=1 and height=10576.00)
After adding a constant surface, when I press the reset button I get the
following message:
Error: floating-pont value too large to represent
loating-point value too large to represent
floating-point value too large to represent
while executing
"expr int($val * 1)"
(procedure "Nv_floatscaleCallback" line 57)
invoked from within
"Nv_floatscaleCallback $E b 2 Nchange_exag $val"
(procedure "do_reset" line 12)
invoked from within
"do_reset .top2.panelarea.panels.main.midf.pos \
.top2.panelarea.panels.main.midf.height \
.top2.panelarea.panels.main.midf.zexag \
.top2.panelarea.panels.ma..."
invoked from within
".top2.panelarea.panels.main.bframe.reset invoke"
("uplevel" body line 1)
invoked from within
"uplevel #0 [list $w invoke]"
(procedure "tk::ButtonUp" line 22)
invoked from within
"tk::ButtonUp .top2.panelarea.panels.main.bframe.reset"
(command bound to event)
I think that the bug resides in "exag.c" file (folder
visualization/nviz/src/ of the GRASS source tree), in the functions
"Nget_first_exag_cmd" and "Nget_height_cmd", they both use
"GS_get_exag_guess" function which can return a very high value if one of
the surface is one the one describes before ("constant" or "goelogy" in
the spearfish data set for example).
I've made a little change to this code and that seems to do the trick:
--- exag.c 2005-11-23 10:47:46.000000000 +1000
+++ exag.c.old 2005-11-23 10:48:33.000000000 +1000
@@ -67,7 +67,7 @@
exag = 0.0;
for (i = 0; i < nsurfs; i++) {
if (GS_get_exag_guess(surf_list[0], &texag) > -1) {
- if (texag && texag <= 10)
+ if (texag)
exag = (texag > exag) ? texag : exag;
@@ -104,7 +104,7 @@
exag = 0.0;
if (GS_get_exag_guess(surf_list[i], &texag) > -1)
+ if (texag)
exag = texag > exag ? texag : exag;
if (exag == 0.0)
Another bug is when I try to load a state in NVIZ with several surfaces,
the surf panel is not updated correctly, if NVIZ is loaded with 3 surfaces
for example, I can only see one in the surface panel.
I've made a little change to the panel_surf.tcl file and that seems to
work fine:
--- panel_surf.tcl 2005-11-23 14:25:55.000000000 +1000
+++ panel_surf.tcl.old 2005-11-23 14:26:16.000000000 +1000
@@ -258,8 +258,6 @@
# Load procedure for loading state of Nviz
proc Nviz_surf_load { file_hook } {
- Nviz_surf_reset
# Read the number of surfaces saved in this state file
gets $file_hook num_surfs
I've made several tests after these changes, and it seems to work fine.
Hope that helps.
Regards.
Stéphane Bidet <stephane.bidet at tremplin-utc.net>
VISLAB developer
http://www.vislab.uq.edu.au/
