[GRASS5] Parallel GRASS modules for high performance
Helena Mitasova hmitaso at unity.ncsu.edu
Sun Nov 27 23:24:09 EST 2005
On Nov 26, 2005, at 3:49 AM, Yann Chemin wrote:
> What are generally the things that change through release cycles?
it can be a lot - especially for 5->6 site format used by the
interpolation modules was retired,
point data are now handled as vector data and s.surf.rst was merged
with v.surf.rst.
The latest parallelization of s.surf.rst that I mentioned (you can look
at it, see the link below,
it was well done both for 2D and 3D using MPI) was done at the
segmentation level -
each segment was sent to a different processor. Although the
segmentation remains the same
I am not sure how much work it would be to update it to GRASS6 and
there indeed needs to be some IFDEF
condition so that you don't end up with two versions of the same module
(you can then be almost
sure that the parallel version will be the one that won't live too
long).
GRASS6 -> GRASS7 may get a new raster format.
>  our experience with very simple MPI parallelization is that it can be
> incorporated in a code relatively easily. The module may be compiled
> and run sequentially, but with some IFDEF conditions, the sequential
> loop maybe osculted and another version of the loop maybe compiled
> with MPI if configured with it. So in that case, the code is holding
> (though a bit longer) both types of infrastructures. People may port
> the sequential anytime, and if happens to have a "parallel" user, most
> likely the compilation trouble shooting will be limited to MPI code.
>  we did not try that IFDEF trick yet but it is something we want to
> end up doing with our MPI and NinfG GRASS modules.
This sounds like a good idea, there is a lot of interest in parallel
GRASS capabilities and eventually somebody
will find a solution that will be used beyond a single project - Good
luck with your effort,
Helena
>  0.02 cents
> On 11/26/05, Helena Mitasova <hmitaso at unity.ncsu.edu> wrote:
>> of interpolation and other modules
>> have been written since 1993, there should be a link to parallel idw
>> on
>> the grass web site and a parallel
>>  version of the s.surf.rst module is here:
>> http://skagit.meas.ncsu.edu/~helena/grasswork/grasscontrib/
>> rstmods2fixed.tar.gz
>> The problem with these implementations is that unless the developer is
>> committed to keeping them up to date
>> they die pretty quickly (e.g. the rst works with GRASS5 but not
>> GRASS6).
>> So I have been begging everybody who tries to do parallel stuff for
>> grass to do the parallelization
>> on top of the modules rather than within the modules so that they are
>> minimally dependent on changes
>> within the modules. For example, v.surf.rst can be run efficiently by
>> splitting region into smaller overlapping subregions
>> and sending each subregion to a different processor and then patch the
>> results together. Same can be
>> done for r.mapcalc , r.slope.aspect and many other modules (there are
>> some exceptions such as modules
>> that include flow routing). This may have its own problems but it is
>> definitely more general and has much better
>> chance of surviving beyond one release cycle than writing a parallel
>> version of a module.
>> I have plenty of large data sets (tens to hundreds of millions of
>> points) but you need to get GRASS read them first.
>> Helena
>> On Nov 25, 2005, at 12:33 PM, Muzaffer Ayvaz wrote:
>> > Hi;
>> > Some modules in GRASS, especially surface generation modules, takes
>> > long times according to the our data and our parameters.I am trying
>> to
>> > write parallel versions of theese modules via MPI library, to be
>> able
>> > to run GRASS in high performance parallel machines..
>> > I have looked mailing list archives, and there is a people who is
>> > trying to do also same thing. But this mail was in 1993. I couldnt
>> > reach this person.
>> > Now, I want to hear about your experiences. Does anybody try
>> > samething? or Does anybody can give me knowledge about the
>> compilation
>> > of GRASS with this library (MPI), -mpcc must be used to compile-? Or
>> > do you have large data sets for surface generation.
>> > Or which modules takes longs time in additon to the surface
>> generation
>> > modules,
>> > I mean minutes, hours or more.
>> > Tha! nk you for all
>> > Your respectfully
>> > Muzaffer Ayvaz
>> > Yahoo! Music Unlimited - Access over 1 million songs. Try it free.
>> Helena Mitasova
>> Dept. of Marine, Earth and Atm. Sciences
>> 1125 Jordan Hall, NCSU Box 8208,
>> Raleigh NC 27695
>> grass5 mailing list
>> grass5 at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass5
Helena Mitasova
Raleigh NC 27695
