[GRASS5] [bug #3869] (grass) g.remove fails on vector map if raster reclass map present
Request Tracker grass-bugs at intevation.de
Tue Nov 29 12:17:47 EST 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3869
Subject: g.remove fails on vector map if raster reclass map present
grass obtained from: CVS
grass binary for platform: Compiled from Sources
hi,
an "amusing" bug:
g.remove vect=roads_roads_roads_roads_roads_roads_roads
[roads_roads_roads_roads_roads_roads_roads at sqlite] is a base map. Remove reclassed maps first:
 interstate at user1,roads.rcl at user1
IMHO g.remove vect=... should not no bother about raster (reclass) maps
with identical name.
g.list vect
Vorhandene vector Dateien im Mapset sqlite:
myfields    roads_roads_roads_roads_roads_roads_roads      spearfish_soils
mypoints3D  roads_roads_roads_roads_roads_roads_roads_buf  test
g.list rast
Vorhandene raster Dateien im Mapset sqlite:
myfields_v_rast_stats.21322  roads_roads_roads_roads_roads_roads_roads
[the stupid name was selected to tract a gui.tcl bug, instead I discovered
this one].
Markus
-------------------------------------------- Managed by Request Tracker
