[GRASS5] ps.map supports grassrgb
Martin Landa landa.martin at gmail.com
Sun Oct 2 07:56:28 EDT 2005
Hi all,
I have tried to add grassrgb instruction in ps.map module. See the
diffs and sample figure in the attachment. Also lib/vector/Vlib/area.c
should be patched (but it is part of d_vect_rgb_column.diffs...).
Best regards, Martin
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20051002/6eeb6eac/ps_map-grassrgb.diff.gz
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20051002/6eeb6eac/rgbmap.eps.gz
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20051002/6eeb6eac/area.c.diff.gz
