[GRASS5] config error 'ar' on OS X
Sat Oct 8 06:07:25 EDT 2005
Kirk R. Wythers wrote:
> > this looks like a CVS conflict in the file.
> > Did you run autoconf? You will have to check the output
> > of
> > cvs up configure
> > If unexpected, delete the file and fetch it again (all configure
> > changes should be generally made in configure.in, if this applies
> Thanks Markus, cvs up configure yields:
> C configure
> Are you suggesting that I delete the configure file, run autoconfig
> to re-crreate configure, then re-run cvs up -dP?
Just delete the configure file then run "cvs up -dP". If you run
autoconf yourself, you'll get a conflict.
Changes to configure.in can usually be merged automatically, but the
same doesn't apply to configure. Apart from anything else, any change
will throw off the line numbers.
