[GRASS5] config error 'ar' on OS X
Kirk R. Wythers
kwythers at umn.edu
Fri Oct 7 17:27:56 EDT 2005
On Oct 7, 2005, at 4:08 PM, Markus Neteler wrote:
> Kirk,
> this looks like a CVS conflict in the file.
> Did you run autoconf? You will have to check the output
> of
> cvs up configure
> If unexpected, delete the file and fetch it again (all configure
> changes should be generally made in configure.in, if this applies
> here).
> good luck
> Markus
Thanks Markus, cvs up configure yields:
C configure
Are you suggesting that I delete the configure file, run autoconfig
to re-crreate configure, then re-run cvs up -dP?
Kirk
