[GRASS5] config error 'ar' on OS X
Markus Neteler
neteler at itc.it
Fri Oct 7 17:08:38 EDT 2005
On Fri, Oct 07, 2005 at 04:02:11PM -0500, Kirk R. Wythers wrote:
> I am getting a configure error I don't recognize after cvs up today.
> The error refers to 'ar'. What is ar?
> checking for ar... ar
> ./configure: line 2192: syntax error near unexpected token `<<<'
> ./configure: line 2192: `<<<<<<< configure'
> Thanks,
Kirk,
this looks like a CVS conflict in the file.
Did you run autoconf? You will have to check the output
of
cvs up configure
If unexpected, delete the file and fetch it again (all configure
changes should be generally made in configure.in, if this applies
here).
good luck
Markus
