[GRASS5] Re: [GRASSLIST:8545] Re: d.m - commands output pollute
the Grass terminal
Moritz Lennert
mlennert at club.worldonline.be
Mon Oct 10 03:43:06 EDT 2005
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Glynn Clements wrote:
> Moritz Lennert wrote:
>>As a side remark, this might be an argument for avoiding arguments
>>with spaces whenever possible. For example, in d.vect.thematique, it
>>might be better to find other names for arguments such as 'graduated
>>colors', 'custom gradient', 'standard deviation', etc.
> No need. Tcl has perfectly good support for lists; there's no reason
> to treat a command as a string.
Well, my remark was meant for the command line, where you have to
know that you have to put some of the options between quotes because
there are spaces between them. I just think it would make life
easier for everyone if we avoid option names with spaces in them...
Moritz
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFDShuKrIrMbm76jD8RAngqAJ4ho6Mku14ScnpLe7GZv6MuhsYXTACfV4TA
auyCnNehshtvezUhprKr+cY=
=vz4d
-----END PGP SIGNATURE-----
