[GRASS5] Re: [GRASSLIST:8620] Re: GRASS, gdal and mapserver
Radim Blazek
radim.blazek at gmail.com
Fri Oct 14 05:38:01 EDT 2005
Vector library is obviously missing.
Radim
On 10/13/05, Francisco Alonso <alonsarp at um.es> wrote:
> El Viernes, 14 de Octubre de 2005 10:25, Radim Blazek escribió:
> > On 10/12/05, Francisco Alonso <alonsarp at um.es> wrote:
> > > # ogrinfo
> > > /var/www/grass5_mapserver/spearfish60/PERMANENT/vector/streams/head
> > > Warning 1: GRASS warning: GISBASE enviroment variable was not set, using:
> > > /usr/local/grass-6.0.1
> > > ogrinfo: relocation error: /usr/local/lib/gdalplugins/ogr_GRASS.so:
> > > undefined symbol: Vect_set_fatal_error
> > ldd /usr/local/lib/gdalplugins/ogr_GRASS.so ?
> > Radim
> # ldd /usr/local/lib/gdalplugins/ogr_GRASS.so
> libgrass_I.so => /usr/lib/libgrass_I.so (0x40014000)
> libgrass_vask.so => /usr/lib/libgrass_vask.so (0x40026000)
> libgrass_gmath.so => /usr/lib/libgrass_gmath.so (0x4002c000)
> libgrass_gis.so => /usr/lib/libgrass_gis.so (0x40032000)
> libgrass_datetime.so => /usr/lib/libgrass_datetime.so (0x400b9000)
> libgrass_gproj.so => /usr/lib/libgrass_gproj.so (0x400c1000)
> libgdal.so.1 => /usr/lib/libgdal.so.1 (0x400c9000)
> libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x40493000)
> libm.so.6 => /lib/tls/libm.so.6 (0x4054d000)
> libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x4056f000)
> libc.so.6 => /lib/tls/libc.so.6 (0x40578000)
> libfftw.so.2 => /usr/lib/libfftw.so.2 (0x406ad000)
> libz.so.1 => /usr/lib/libz.so.1 (0x406e1000)
> libncurses.so.5 => /lib/libncurses.so.5 (0x406f4000)
> libproj.so.0 => /usr/lib/libproj.so.0 (0x40733000)
> libgeos.so.2 => /usr/lib/libgeos.so.2 (0x40768000)
> libpq.so.3 => /usr/lib/libpq.so.3 (0x4085b000)
> librt.so.1 => /lib/tls/librt.so.1 (0x40876000)
> libdl.so.2 => /lib/tls/libdl.so.2 (0x4087c000)
> libodbc.so.1 => /usr/lib/libodbc.so.1 (0x40880000)
> libxerces-c.so.26 => /usr/lib/libxerces-c.so.26 (0x408f8000)
> libjasper-1.701.so.1 => /usr/lib/libjasper-1.701.so.1 (0x40c42000)
> libmfhdf.so.4 => /usr/lib/libmfhdf.so.4 (0x40c8f000)
> libdf.so.4 => /usr/lib/libdf.so.4 (0x40cb1000)
> libungif.so.4 => /usr/lib/libungif.so.4 (0x40d50000)
> libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40d59000)
> libtiff.so.4 => /usr/lib/libtiff.so.4 (0x40d77000)
> libpng12.so.0 => /usr/lib/libpng12.so.0 (0x40dc7000)
> libnetcdf.so.3 => /usr/lib/libnetcdf.so.3 (0x40dec000)
> libcfitsio.so.2 => /usr/lib/libcfitsio.so.2 (0x40e0f000)
> libpthread.so.0 => /lib/tls/libpthread.so.0 (0x40f7d000)
> /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
> libssl.so.0.9.7 => /usr/lib/i686/cmov/libssl.so.0.9.7 (0x40f8d000)
> libcrypto.so.0.9.7 => /usr/lib/i686/cmov/libcrypto.so.0.9.7
> (0x40fbe000)
> libkrb5.so.3 => /usr/lib/libkrb5.so.3 (0x410bd000)
> libcrypt.so.1 => /lib/tls/libcrypt.so.1 (0x41125000)
> libresolv.so.2 => /lib/tls/libresolv.so.2 (0x41152000)
> libnsl.so.1 => /lib/tls/libnsl.so.1 (0x41164000)
> libltdl.so.3 => /usr/lib/libltdl.so.3 (0x41179000)
> libk5crypto.so.3 => /usr/lib/libk5crypto.so.3 (0x41180000)
> libcom_err.so.2 => /lib/libcom_err.so.2 (0x411a3000)
> Seems to be ok
> Paco
> Francisco Alonso Sarría
> Departamento de Geografía (Area de Geografía Física)
> Universidad de Murcia. Campus La Merced
> E-30001 Murcia
> Telfn: +34 968364357
> www.um.es/geograf/sigmur
