[GRASS5] Re: [GRASSLIST:8620] Re: GRASS, gdal and mapserver
Markus Neteler neteler at itc.it
Fri Oct 14 05:48:38 EDT 2005
On Fri, Oct 14, 2005 at 11:38:01AM +0200, Radim Blazek wrote:
> Vector library is obviously missing.
Right, for the new GDAL-OGR-GRASS plugin you need to link
as many as these libs:
cd /usr/local/lib
ln -s /usr/local/grass6/lib/libgrass_I.so .
ln -s /usr/local/grass6/lib/libgrass_vask.so .
ln -s /usr/local/grass6/lib/libgrass_gmath.so .
ln -s /usr/local/grass6/lib/libgrass_gis.so .
ln -s /usr/local/grass6/lib/libgrass_datetime.so .
ln -s /usr/local/grass6/lib/libgrass_vect.so .
ln -s /usr/local/grass6/lib/libgrass_dig2.so .
ln -s /usr/local/grass6/lib/libgrass_dbmiclient.so .
ln -s /usr/local/grass6/lib/libgrass_dbmibase.so .
ln -s /usr/local/grass6/lib/libgrass_shape.so .
ln -s /usr/local/grass6/lib/libgrass_dgl.so .
ln -s /usr/local/grass6/lib/libgrass_rtree.so .
ln -s /usr/local/grass6/lib/libgrass_linkm.so .
ln -s /usr/local/grass6/lib/libgrass_form.so .
ln -s /usr/local/grass6/lib/libgrass_gproj.so .
(paths may differ)
Then it will work.
Markus
> On 10/13/05, Francisco Alonso <alonsarp at um.es> wrote:
> > El Viernes, 14 de Octubre de 2005 10:25, Radim Blazek escribió:
> > > On 10/12/05, Francisco Alonso <alonsarp at um.es> wrote:
> > > > # ogrinfo
> > > > /var/www/grass5_mapserver/spearfish60/PERMANENT/vector/streams/head
> > > > Warning 1: GRASS warning: GISBASE enviroment variable was not set, using:
> > > > /usr/local/grass-6.0.1
> > > > ogrinfo: relocation error: /usr/local/lib/gdalplugins/ogr_GRASS.so:
> > > > undefined symbol: Vect_set_fatal_error
> > > ldd /usr/local/lib/gdalplugins/ogr_GRASS.so ?
> > > Radim
> > # ldd /usr/local/lib/gdalplugins/ogr_GRASS.so
> >                 libgrass_I.so => /usr/lib/libgrass_I.so (0x40014000)
> >         libgrass_vask.so => /usr/lib/libgrass_vask.so (0x40026000)
> >         libgrass_gmath.so => /usr/lib/libgrass_gmath.so (0x4002c000)
> >         libgrass_gis.so => /usr/lib/libgrass_gis.so (0x40032000)
> >         libgrass_datetime.so => /usr/lib/libgrass_datetime.so (0x400b9000)
> >         libgrass_gproj.so => /usr/lib/libgrass_gproj.so (0x400c1000)
> >         libgdal.so.1 => /usr/lib/libgdal.so.1 (0x400c9000)
> >         libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x40493000)
> >         libm.so.6 => /lib/tls/libm.so.6 (0x4054d000)
> >         libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x4056f000)
> >         libc.so.6 => /lib/tls/libc.so.6 (0x40578000)
> >         libfftw.so.2 => /usr/lib/libfftw.so.2 (0x406ad000)
> >         libz.so.1 => /usr/lib/libz.so.1 (0x406e1000)
> >         libncurses.so.5 => /lib/libncurses.so.5 (0x406f4000)
> >         libproj.so.0 => /usr/lib/libproj.so.0 (0x40733000)
> >         libgeos.so.2 => /usr/lib/libgeos.so.2 (0x40768000)
> >         libpq.so.3 => /usr/lib/libpq.so.3 (0x4085b000)
> >         librt.so.1 => /lib/tls/librt.so.1 (0x40876000)
> >         libdl.so.2 => /lib/tls/libdl.so.2 (0x4087c000)
> >         libodbc.so.1 => /usr/lib/libodbc.so.1 (0x40880000)
> >         libxerces-c.so.26 => /usr/lib/libxerces-c.so.26 (0x408f8000)
> >         libjasper-1.701.so.1 => /usr/lib/libjasper-1.701.so.1 (0x40c42000)
> >         libmfhdf.so.4 => /usr/lib/libmfhdf.so.4 (0x40c8f000)
> >         libdf.so.4 => /usr/lib/libdf.so.4 (0x40cb1000)
> >         libungif.so.4 => /usr/lib/libungif.so.4 (0x40d50000)
> >         libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40d59000)
> >         libtiff.so.4 => /usr/lib/libtiff.so.4 (0x40d77000)
> >         libpng12.so.0 => /usr/lib/libpng12.so.0 (0x40dc7000)
> >         libnetcdf.so.3 => /usr/lib/libnetcdf.so.3 (0x40dec000)
> >         libcfitsio.so.2 => /usr/lib/libcfitsio.so.2 (0x40e0f000)
> >         libpthread.so.0 => /lib/tls/libpthread.so.0 (0x40f7d000)
> >         /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
> >         libssl.so.0.9.7 => /usr/lib/i686/cmov/libssl.so.0.9.7 (0x40f8d000)
> >         libcrypto.so.0.9.7 => /usr/lib/i686/cmov/libcrypto.so.0.9.7
> > (0x40fbe000)
> >         libkrb5.so.3 => /usr/lib/libkrb5.so.3 (0x410bd000)
> >         libcrypt.so.1 => /lib/tls/libcrypt.so.1 (0x41125000)
> >         libresolv.so.2 => /lib/tls/libresolv.so.2 (0x41152000)
> >         libnsl.so.1 => /lib/tls/libnsl.so.1 (0x41164000)
> >         libltdl.so.3 => /usr/lib/libltdl.so.3 (0x41179000)
> >         libk5crypto.so.3 => /usr/lib/libk5crypto.so.3 (0x41180000)
> >         libcom_err.so.2 => /lib/libcom_err.so.2 (0x411a3000)
> > Seems to be ok
> > Paco
> > Francisco Alonso Sarría
> > Departamento de Geografía (Area de Geografía Física)
> > Universidad de Murcia. Campus La Merced
> > E-30001 Murcia
> > Telfn: +34 968364357
> > www.um.es/geograf/sigmur
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
