[GRASS5] Re: [GRASSLIST:8620] Re: GRASS, gdal and mapserver
Francisco Alonso alonsarp at um.es
Thu Oct 13 16:07:29 EDT 2005
Hi all:
May be I have mised some step:
1- I compiled gdal without grass
2- I compiled grass with gdal (v.in.ogr, v.out.ogr, etc. work fine)
3- I compile the gdal-grass package (fixing some problems in the Makefile to
access grass vector libraries)
4- I stored ogr_GRASS.so and gdal_GRASS.so a in /usr/local/lib/gdalplugins/
Now ogrinfo and gdalinfo can read GRASS files because they load the plugins
# gdalinfo  --formats|grep GRASS
  GRASS (ro): GRASS Database Rasters (5.7+)
# ogrinfo  --formats|grep GRASS
  -> "GRASS" (readonly)
but gdal-config is a script created before the plugins and aparently doesn't
know about them
# gdal-config --formats
gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 xpm sdts raw dted mem jdem
envisat elas fit vrt usgsdem l1b nitf bmp pcidsk airsar rs2 ilwis rmf rik bsb
gif jpeg png pcraster
probably the same problem with libgdal.so and when I compile mapserver it
doesn't think he can read GRASS files.
I think I missed something,  I'm not to sure about what ldconfig does but I
have run it each time I made a change ;-)
Any idea
Thanks in advance
PAco
> Vector library is obviously missing.
> Radim
> On 10/13/05, Francisco Alonso <alonsarp at um.es> wrote:
> > El Viernes, 14 de Octubre de 2005 10:25, Radim Blazek escribió:
> > > On 10/12/05, Francisco Alonso <alonsarp at um.es> wrote:
> > > > # ogrinfo
> > > > /var/www/grass5_mapserver/spearfish60/PERMANENT/vector/streams/head
> > > > Warning 1: GRASS warning: GISBASE enviroment variable was not set,
> > > > using: /usr/local/grass-6.0.1
> > > > ogrinfo: relocation error: /usr/local/lib/gdalplugins/ogr_GRASS.so:
> > > > undefined symbol: Vect_set_fatal_error
> > > ldd /usr/local/lib/gdalplugins/ogr_GRASS.so ?
> > > Radim
> > # ldd /usr/local/lib/gdalplugins/ogr_GRASS.so
> >                 libgrass_I.so => /usr/lib/libgrass_I.so (0x40014000)
> >         libgrass_vask.so => /usr/lib/libgrass_vask.so (0x40026000)
> >         libgrass_gmath.so => /usr/lib/libgrass_gmath.so (0x4002c000)
> >         libgrass_gis.so => /usr/lib/libgrass_gis.so (0x40032000)
> >         libgrass_datetime.so => /usr/lib/libgrass_datetime.so
> > (0x400b9000) libgrass_gproj.so => /usr/lib/libgrass_gproj.so (0x400c1000)
> > libgdal.so.1 => /usr/lib/libgdal.so.1 (0x400c9000)
> >         libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x40493000)
> >         libm.so.6 => /lib/tls/libm.so.6 (0x4054d000)
> >         libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x4056f000)
> >         libc.so.6 => /lib/tls/libc.so.6 (0x40578000)
> >         libfftw.so.2 => /usr/lib/libfftw.so.2 (0x406ad000)
> >         libz.so.1 => /usr/lib/libz.so.1 (0x406e1000)
> >         libncurses.so.5 => /lib/libncurses.so.5 (0x406f4000)
> >         libproj.so.0 => /usr/lib/libproj.so.0 (0x40733000)
> >         libgeos.so.2 => /usr/lib/libgeos.so.2 (0x40768000)
> >         libpq.so.3 => /usr/lib/libpq.so.3 (0x4085b000)
> >         librt.so.1 => /lib/tls/librt.so.1 (0x40876000)
> >         libdl.so.2 => /lib/tls/libdl.so.2 (0x4087c000)
> >         libodbc.so.1 => /usr/lib/libodbc.so.1 (0x40880000)
> >         libxerces-c.so.26 => /usr/lib/libxerces-c.so.26 (0x408f8000)
> >         libjasper-1.701.so.1 => /usr/lib/libjasper-1.701.so.1
> > (0x40c42000) libmfhdf.so.4 => /usr/lib/libmfhdf.so.4 (0x40c8f000)
> >         libdf.so.4 => /usr/lib/libdf.so.4 (0x40cb1000)
> >         libungif.so.4 => /usr/lib/libungif.so.4 (0x40d50000)
> >         libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40d59000)
> >         libtiff.so.4 => /usr/lib/libtiff.so.4 (0x40d77000)
> >         libpng12.so.0 => /usr/lib/libpng12.so.0 (0x40dc7000)
> >         libnetcdf.so.3 => /usr/lib/libnetcdf.so.3 (0x40dec000)
> >         libcfitsio.so.2 => /usr/lib/libcfitsio.so.2 (0x40e0f000)
> >         libpthread.so.0 => /lib/tls/libpthread.so.0 (0x40f7d000)
> >         /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
> >         libssl.so.0.9.7 => /usr/lib/i686/cmov/libssl.so.0.9.7
> > (0x40f8d000) libcrypto.so.0.9.7 => /usr/lib/i686/cmov/libcrypto.so.0.9.7
> > (0x40fbe000)
> >         libkrb5.so.3 => /usr/lib/libkrb5.so.3 (0x410bd000)
> >         libcrypt.so.1 => /lib/tls/libcrypt.so.1 (0x41125000)
> >         libresolv.so.2 => /lib/tls/libresolv.so.2 (0x41152000)
> >         libnsl.so.1 => /lib/tls/libnsl.so.1 (0x41164000)
> >         libltdl.so.3 => /usr/lib/libltdl.so.3 (0x41179000)
> >         libk5crypto.so.3 => /usr/lib/libk5crypto.so.3 (0x41180000)
> >         libcom_err.so.2 => /lib/libcom_err.so.2 (0x411a3000)
Francisco Alonso Sarría
Departamento de Geografía (Area de Geografía Física)
Universidad de Murcia. Campus La Merced
E-30001 Murcia
Telfn: +34 968364357
www.um.es/geograf/sigmur
