[GRASS5] DB default settings now defined in new mapset
Markus Neteler
neteler at itc.it
Tue Oct 18 05:42:52 EDT 2005
I have fixed the lack of default DBF DB settings when
creating a new mapset. Now both the text interface and the
GUI create the dbf/ directory in a newly created mapset
and copy over the VAR file from PERMANENT which contains
the default DB settings.
Fixed in both 6.0-CVS (for 6.0.2) and 6.1-CVS.
A user can certainly modify the settings with db.connect as
before.
Markus
