[GRASS5] DB default settings now defined in new mapset
Markus Neteler neteler at itc.it
Tue Oct 18 12:17:58 EDT 2005
Hi again,
update:
I have fixed the lack of default DBF DB settings when
creating a new mapset. Now both the text interface and the
GUI create the dbf/ directory in a newly created mapset
and generate a new VAR file which contains the default DB
settings to DBF.
Fixed again in both 6.0-CVS (for 6.0.2) and 6.1-CVS.
A user can certainly modify the settings with db.connect as
before.
cheers
 Markus
