[GRASS5] DB default settings now defined in new mapset
Tue Oct 18 18:22:28 EDT 2005
> I have fixed the lack of default DBF DB settings when
> creating a new mapset. Now both the text interface and the
> GUI create the dbf/ directory in a newly created mapset
> and generate a new VAR file which contains the default DB
> settings to DBF.
> Fixed again in both 6.0-CVS (for 6.0.2) and 6.1-CVS.
> A user can certainly modify the settings with db.connect as
> before.
just as a historical note, the v.in.garmin script has a test & shell
code for this.
Hamish
