[GRASS5] d.vect -a|c for all types ver2
Radim Blazek radim.blazek at gmail.com
Wed Oct 19 04:14:16 EDT 2005
On 10/6/05, Martin Landa <landa.martin at gmail.com> wrote:
> Hi all,
> I have rewritten the patch for d.vect which enables to use flags -a
> and -c for all vector types (not only for areas). I hope I did it
> better this time (for previous patch see
> http://grass.itc.it/pipermail/grass5/2005-September/019563.html).
> best regards, Martin
The area.c.diff seems to be correct but also the last return should be -1.
Radim
