[GRASS5] d.vect -a|c for all types ver2
Martin Landa landa.martin at gmail.com
Thu Oct 6 05:18:33 EDT 2005
Hi all,
I have rewritten the patch for d.vect which enables to use flags -a
and -c for all vector types (not only for areas). I hope I did it
better this time (for previous patch see
http://grass.itc.it/pipermail/grass5/2005-September/019563.html).
best regards, Martin
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20051006/0776ca17/d_vect_rgb_column-2005-10-06.diff.gz
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20051006/0776ca17/area.c.diff.gz
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20051006/0776ca17/d_vect-rgb.png
