[GRASS5] Re: question about sqlite
Markus Neteler
neteler at itc.it
Wed Oct 19 05:07:02 EDT 2005
Radim Blazek wrote:
>On 10/18/05, Michael Barton <michael.barton at asu.edu> wrote:
>>Radim,
>>Could you give me a quick overview of what it means to compile GRASS with
>>sqlite? Here are a couple questions I have.
>>1) Is it simply a driver that lets GRASS recognize a database/table created
>>by sqlite in an active sqlite session started in another process, like a
>>Postgresql table in an active Postgresql session?
>>2) Does it/can it active an sqlite session from within GRASS?
>>3) Are there other features that I'm not asking about that I should know?
>The sqlite driver works like any other db driver (dbf, pg, mysql, odbc).
>You can use an existing database or create a new one from GRASS.
>Just set the driver and database file with db.connect and all new
>attribute tables will be created in that database.
I have updated the db.connect man/html page accordingly in CVS to
reflect the existance of sqlite.
Markus
