[GRASS5] Re: question about sqlite
Wed Oct 19 12:56:04 EDT 2005
Radim Blazek wrote:
> > Could you give me a quick overview of what it means to compile GRASS with
> > sqlite? Here are a couple questions I have.
> > 1) Is it simply a driver that lets GRASS recognize a database/table created
> > by sqlite in an active sqlite session started in another process, like a
> > Postgresql table in an active Postgresql session?
> > 2) Does it/can it active an sqlite session from within GRASS?
> > 3) Are there other features that I'm not asking about that I should know?
> The sqlite driver works like any other db driver (dbf, pg, mysql, odbc).
With the addition of SQLite, is there any reason to continue to
support the DBF driver?
