[GRASS5] d.vect -a|c for all types ver2
Martin Landa
landa.martin at gmail.com
Sun Oct 23 18:27:12 EDT 2005
I have tried to solve this problem - I am really not sure, maybe I
don't understand correctly areas and isles...
There is a new patch for d.vect... I hope without any huge bugs;-)
Please test it ... I am ready for your comments.
Best regards,
Martin
2005/10/20, Markus Neteler <neteler at itc.it>:
> On Tue, Oct 18, 2005 at 07:12:38PM +0200, Markus Neteler wrote:
> > On Thu, Oct 06, 2005 at 09:18:33AM +0000, Martin Landa wrote:
> > > Hi all,
> > > I have rewritten the patch for d.vect which enables to use flags -a
> > > and -c for all vector types (not only for areas). I hope I did it
> > > better this time (for previous patch see
> > > http://grass.itc.it/pipermail/grass5/2005-September/019563.html).
> Hi Martin,
> I tested the new d.vect code (the Vlib/area.c fix is in CVS),
> but there is a bug in d.vect/area.c:
> d.vect delauney
> ERROR: Attempt to read topo for dead isle (2)
> The problem is the line:
> if (Vect_get_isle_area(Map, area))
> Since this function ends with a fatal error for non-island
> areas, it must be used in a different way.
> However, for details better ask Radim...
> I am sure that you'll iron out this missing piece!
> Markus
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20051024/a9d12d52/d_vect_rgb_column-2005-10-23.diff.gz
--- d.vect.18/area.c 2005-10-24 00:03:10.000000000 +0200
+++ d.vect/area.c 2005-10-24 00:18:39.000000000 +0200
@@ -20,8 +20,9 @@
struct line_cats *Cats;
int cat, centroid = 0;
int red, grn, blu;
+ struct ilist *isles = NULL;
- struct field_info *fi=NULL;
+ struct field_info *fi = NULL;
dbDriver *driver = NULL;
dbCatValArray cvarr;
dbCatVal *cv_rgb = NULL;
@@ -72,14 +73,26 @@
num = Vect_get_num_areas(Map);
G_debug (2, "n_areas = %d", num);
+ /* initialize isles - needed? */
+ isles = Vect_new_list ();
+ for ( area = 1; area <= num; area++ ) {
+ n_isles = Vect_get_area_num_isles ( Map, area );
+ for ( i = 0; i < n_isles; i++) {
+ isle = Vect_get_area_isle ( Map, area, i );
+ if (isle > 0) {
+ Vect_list_append (isles, isle);
int i;
BOUND_BOX box;
G_debug (3, "area = %d", area);
- if ( !Vect_area_alive (Map, area) ) continue;
+ if ( !Vect_area_alive (Map, area) || Vect_val_in_list(isles, area)) continue;
/* Check box */
Vect_get_area_box (Map, area, &box);
if ( box.N < window->south || box.S > window->north ||
@@ -136,7 +149,7 @@
Vect_append_points ( Points, IPoints, GV_FORWARD);
Vect_append_point ( Points, xl, yl, 0.0 ); /* ??? */
if( table_colors_flag ) {
cat=Vect_get_area_cat ( Map, area , Clist -> field );
centroid = Vect_get_area_centroid ( Map, area );
@@ -196,20 +209,15 @@
if ( fcolor > -1 ) {
- if (Vect_get_isle_area (Map, area)) { /* isle ? */
- R_RGB_color (255, 255, 255);
+ if (!table_colors_flag && !cats_color_flag) {
+ R_color(fcolor) ;
else {
- if (!table_colors_flag && !cats_color_flag) {
- R_color(fcolor) ;
+ if (rgb) {
+ R_RGB_color ((unsigned char) red, (unsigned char) grn, (unsigned char) blu);
else {
- if (rgb) {
- R_RGB_color ((unsigned char) red, (unsigned char) grn, (unsigned char) blu);
- else {
R_color (fcolor);
G_plot_polygon ( Points->x, Points->y, Points->n_points);
@@ -239,8 +247,10 @@
} /* end for */
Vect_destroy_line_struct (Points);
+ Vect_destroy_line_struct (IPoints);
Vect_destroy_cats_struct (Cats);
+ Vect_destroy_list (isles);
return 0;
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20051024/a9d12d52/test.png
