[GRASS5] r.profile and LatLong coords input?
Markus Neteler
neteler at itc.it
Mon Oct 24 11:27:23 EDT 2005
Thanks, Bob,
that does the trick. Updated in 6.1-CVS.
(there were two more lines to change).
Markus
On Mon, Oct 24, 2005 at 10:12:50AM -0300, Bob Covill wrote:
> Markus,
> It looks like profile coordinates provided on the command are NOT being
> parsed with G_scan_... . They are being parsed with sscanf which will
> not work with the sexagesimal format.
> If you replace the following lines in main.c (r.profile)
> sscanf(parm.profile->answers[i], "%lf", &e1);
> sscanf(parm.profile->answers[i + 1], "%lf", &n1);
> sscanf(parm.profile->answers[i + 2], "%lf", &e2);
> sscanf(parm.profile->answers[i + 3], "%lf", &n2);
> with
> G_scan_easting(parm.profile->answers[i], &e1, G_projection());
> G_scan_northing(parm.profile->answers[i+1], &n1, G_projection());
> G_scan_easting(parm.profile->answers[i+2], &e2, G_projection());
> G_scan_northing(parm.profile->answers[i+3], &n2, G_projection());
> that should take care of the problem.
> Bob
> Markus Neteler wrote:
> >Hi,
> >I tried to use the current r.profile do compare SRTM V1 and
> >the new SRTM V2 in a LatLong location. Unfortunately coordinate
> >input in sexagesimal format didn't produce any output while
> >decimal degree input does:
> >r.profile N46E011_V1
> >profile=11:09:19.694051E,46:10:38.328612N,11:09:19.694051E,46:02:38.328612N
> >-> nothing, but also no error
> >profile=11.15524237,46.17754171,11.15524237,46.04062008
> >-> results
> >Any ideas? G_scan_easting() and G_scan_northing() seem to be used.
> >Markus
> >_______________________________________________
> >grass5 mailing list
> >grass5 at grass.itc.it
> >http://grass.itc.it/mailman/listinfo/grass5
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
