[GRASS5] Problem with v.in.ogr
    Maik Trömel
    maik.troemel at maitro.net
    Fri Sep  2 07:21:13 EDT 2005
Hello,
i`ve got a problem with v.in.ogr . I want to import a MIF-File. But I get
the following error.
too many nested evaluations (infinite loop?)
    (procedure "GlobalVar::exists" line 1)
    invoked from within
"GlobalVar::exists $_widget($path,var)"
    (procedure "ProgressBar::_modify" line 4)
    invoked from within
"ProgressBar::_modify .dialog0.progress"
    ("eval" body line 1)
    invoked from within
"eval ProgressBar::$cmd .dialog0.progress $args"
    (procedure ".dialog0.progress" line 1)
    invoked from within
"$opt($dlg,progress) _modify"
    (procedure "progress" line 7)
    invoked from within
"progress $dlg $val"
    invoked from within
"if [eof $fh] {
                close $fh
        } else {
                set str [gets $fh]
                append str "\n"
                if { [fblocked $fh] } { set str [read $fh] }
                while {[set idx [string f..."
    (procedure "prnout" line 5)
    invoked from within
"prnout 1 file8"
The File is importet but I can`t convert it to raster-format. I`m sure the
MIF-File is not broken. Does anybody have an idea what the problem could be?
Thanks & Greetings from Karlsruhe (Germany)
Maik Trömel
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20050902/d440df6d/attachment.html
