[GRASS5] Problem with v.in.ogr
Maciek Sieczka werchowyna at epf.pl
Sun Sep 4 03:44:07 EDT 2005
Maik,
It looks like you have this problem in GUI, right?
Can you import your MIF file with v.in.ogr it from the coommand line?
If not, this might be the same problem I reported here:
http://intevation.de/rt/webrt?serial_num=2937&display=History
Maciek
> i`ve got a problem with v.in.ogr . I want to import a MIF-File. But I get
> the following error.
> too many nested evaluations (infinite loop?)
>    (procedure "GlobalVar::exists" line 1)
>    invoked from within
<snip>
