[GRASS5] Problem with v.in.ogr
Maciek Sieczka werchowyna at epf.pl
Sun Sep 4 16:06:45 EDT 2005
Correction:
I have written:
> Maik,
> It looks like you have this problem in GUI, right?
> Can you import your MIF file with v.in.ogr it from the coommand line?
> If not
      I should have written here: "If you can"
> , this might be the same problem I reported here:
> http://intevation.de/rt/webrt?serial_num=2937&display=History
> Maciek
Sorry for the confussion. I hope it is clear what I mean now.
Summarising: this problem with v.in.ogr occures only in GUI.
There is an identical error report,
http://intevation.de/rt/webrt?serial_num=3117, but regarding r.out.pov usage
in GUI.
Maciek
