[GRASS5] [bug #3623] (grass) v.in.ogr fails when input contains a column 'CAT'
Request Tracker
grass-bugs at intevation.de
Mon Sep 12 05:58:18 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3623
Subject: v.in.ogr fails when input contains a column 'CAT'
Platform: GNU/Linux/i386
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: cvs 23.08.05
details:
GRASS 6.1.cvs (caves_utm33):~ > v.in.ogr dsn=/home/trawiarz/poz_fault_patch_cut_pt_extr/poz_fault_patch_cut_pt_extr.shp output=poz_fault_patch_cut_pt_extr_re layer=poz_fault_patch_cut_pt_extr min_area=0.0001 snap=-1
A datum name wgs84 (WGS_1984) was specified without transformation parameters.
Note that the GRASS default for wgs84 is towgs84=0.000,0.000,0.000.
Projection of input dataset and current location appear to match.
Proceeding with import...
Layer: poz_fault_patch_cut_pt_extr
DBMI-DBF driver error:
Column 'CAT' already exists (duplicate name)
Cannot create table.
Error in db_execute_immediate()
GRASS_INFO_ERROR(9053,1): Cannot create table: create table poz_fault_patch_cut_pt_extr_re (cat integer, CAT double precision, WYS double precision, SM double precision, WYS_MULT double precision)
Here's the problematic file:
http://www.biol.uni.wroc.pl/sieczka/udostepnione/vinogr/poz_fault_patch_cut_pt_extr.tar.bz2
It was created in Grass, edited in OO.org and exported with v.out.ogr.
Maciek
-------------------------------------------- Managed by Request Tracker
