[GRASS5] d.vect -a|c for all types
Martin Landa landa.martin at gmail.com
Mon Sep 12 07:53:04 EDT 2005
Hi all,
I have tried to modify (in very simply way) module d.vect. The
attached patch allows to use the flag -c and -a for all vector types -
not only for filling areas.
I also think that function Vect_get_area_cat () in vector/Vlib/area.c
has a small bug. If no category is found it should return "-1" not
"1". Do I understand well?
Thanks for testing,
best regards, Martin
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050912/a27fe51e/d.vect-ac-flags.tar.gz
