[GRASS5] [bug #3627] (grass) v.surf.rst: zcolumn has a default
Radim Blazek radim.blazek at gmail.com
Mon Sep 12 12:00:54 EDT 2005
The zcolumn should not have default value.
Radim
On 9/12/05, Helena Mitasova <hmitaso at unity.ncsu.edu> wrote:
> we put it there as a convenience because flt1 is the default column
> name if you use
> v.in.ascii to import the point data (at least it was the last time I
> tried it).
> This way I can import and interpolate the way I did it
> in GRASS5 without checking the column names. I don't think this is a
> bug, this is a feature.
> Helena
> On Sep 12, 2005, at 9:25 AM, Maciek Sieczka via RT wrote:
> > Correction:
> > This applies not only to GUI as I thought, but to v.surf.rst in
> > general. Why
> > do we have a default for zcolumn? Should there really be one?
> > Maciek
> > P.S.
> > Changing the subject to "v.surf.rst: zcolumn has a default"
> > -------------------------------------------- Managed by Request Tracker
> > grass5 mailing list
> > grass5 at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass5
> Helena Mitasova
> Dept. of Marine, Earth and Atm. Sciences
> 1125 Jordan Hall, NCSU Box 8208,
> Raleigh NC 27695
> http://skagit.meas.ncsu.edu/~helena/
> grass5 mailing list
