[GRASS5] [bug #3627] (grass) v.surf.rst: zcolumn has a default
Jaro Hofierka
hofierka at geomodel.sk
Mon Sep 12 13:19:58 EDT 2005
Radim Blazek wrote:
> The zcolumn should not have default value.
Why not? In interpolation 2D data must always have an attribute
(floating point, no categories). This makes sense to me.
Jaro
> Radim
> On 9/12/05, Helena Mitasova <hmitaso at unity.ncsu.edu> wrote:
>>we put it there as a convenience because flt1 is the default column
>>name if you use
>>v.in.ascii to import the point data (at least it was the last time I
>>tried it).
>>This way I can import and interpolate the way I did it
>>in GRASS5 without checking the column names. I don't think this is a
>>bug, this is a feature.
>>Helena
>>On Sep 12, 2005, at 9:25 AM, Maciek Sieczka via RT wrote:
>>>Correction:
>>>This applies not only to GUI as I thought, but to v.surf.rst in
>>>general. Why
>>>do we have a default for zcolumn? Should there really be one?
>>>Maciek
>>>P.S.
>>>Changing the subject to "v.surf.rst: zcolumn has a default"
>>>-------------------------------------------- Managed by Request Tracker
>>>_______________________________________________
>>>grass5 mailing list
>>>grass5 at grass.itc.it
>>>http://grass.itc.it/mailman/listinfo/grass5
>>Helena Mitasova
>>Dept. of Marine, Earth and Atm. Sciences
>>1125 Jordan Hall, NCSU Box 8208,
>>Raleigh NC 27695
>>http://skagit.meas.ncsu.edu/~helena/
>>grass5 mailing list
> grass5 mailing list
