[GRASS5] [bug #3627] (grass) v.surf.rst: zcolumn has a default
Radim Blazek radim.blazek at gmail.com
Tue Sep 13 03:20:17 EDT 2005
No other 'column' option has a default value.
Column name can be any word, v.in.ascii without definition
of column names is just one possible way to create data
+ it creates columns dbl_1, dbl_2 etc.,
+ if you import x|y|val with v.in.ascii, the column names will be
dbl_1, dbl_2, dbl_3 so it would be necessary to have default
value for z dbl_3. Simply default value for input column name is
not a good idea.
Radim
On 9/12/05, Jaro Hofierka <hofierka at geomodel.sk> wrote:
> Radim Blazek wrote:
> > The zcolumn should not have default value.
> Why not? In interpolation 2D data must always have an attribute
> (floating point, no categories). This makes sense to me.
> Jaro
> > Radim
> > On 9/12/05, Helena Mitasova <hmitaso at unity.ncsu.edu> wrote:
> >>we put it there as a convenience because flt1 is the default column
> >>name if you use
> >>v.in.ascii to import the point data (at least it was the last time I
> >>tried it).
> >>This way I can import and interpolate the way I did it
> >>in GRASS5 without checking the column names. I don't think this is a
> >>bug, this is a feature.
> >>Helena
> >>On Sep 12, 2005, at 9:25 AM, Maciek Sieczka via RT wrote:
> >>>Correction:
> >>>This applies not only to GUI as I thought, but to v.surf.rst in
> >>>general. Why
> >>>do we have a default for zcolumn? Should there really be one?
> >>>Maciek
> >>>P.S.
> >>>Changing the subject to "v.surf.rst: zcolumn has a default"
> >>>-------------------------------------------- Managed by Request Tracker
> >>>_______________________________________________
> >>>grass5 mailing list
> >>>grass5 at grass.itc.it
> >>>http://grass.itc.it/mailman/listinfo/grass5
> >>Helena Mitasova
> >>Dept. of Marine, Earth and Atm. Sciences
> >>1125 Jordan Hall, NCSU Box 8208,
> >>Raleigh NC 27695
> >>http://skagit.meas.ncsu.edu/~helena/
> >>grass5 mailing list
> > grass5 mailing list
