[GRASS5] [bug #3592] (grass) d.vect.thematic: cannot export legend with d.out.png
Michael Barton michael.barton at asu.edu
Mon Sep 19 01:43:51 EDT 2005
This sounds like a very reasonable plan. When they are merged, it would be
nice if the combined one could also draw a circle as well as a box and line.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Hamish <hamish_nospam at yahoo.com>
> Date: Mon, 19 Sep 2005 14:14:55 +1200
> To: Michael Barton <michael.barton at asu.edu>
> Cc: <grass-bugs at intevation.de>, <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] [bug #3592] (grass) d.vect.thematic: cannot export
>> How can d.graph input be added to the command history?
> the input (piped from stdin) is written to a temporary file and the
> command history is changed so that the command line references that
> input file instead of expecting input from stdin. The .tmp file is
> persistent until you quit GRASS at which time it is cleared (possible
> problem with server installs, but d.text already does this eg).
>> Is this something that needs to be added to the d.graph C module?
> Yes.
> I would like to have wish #3241 done first (merge d.mapgraph into
> d.graph)  see http://intevation.de/rt/webrt?serial_num=3241
> step 1) for that is merge the bugfixes and updates from d.mapgraph into
> d.graph (malloc -> G_malloc, ...), otherwise they are essentially the
> same exact code. I would prefer a better C programmer than me did this.
> step 2) add -m flag to d.graph to indicate input coordinates are map
> units, not percentage of frame. I'm happy to do this part.
> We should avoid duplicating the effort of modifying both modules for the
> same feature or allow one module to go off on a tangent which would make
> the merge that much harder in the future.
> Hamish
