[GRASS5] [bug #3654] (grass) sqlite driver doesn't built in Mac OS X
Request Tracker grass-bugs at intevation.de
Mon Sep 19 11:02:32 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3654
Subject: sqlite driver doesn't built in Mac OS X
Platform: Mac OSX
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: grass_61_cvs_050917
sqlite driver is a great add-on for Grass. I have not problem in configure: GRASS see my sqlite 3
installation. I have a problem when Grass build the driver. It doesn't see -lsqlite3. It's strange
This is the result from make:
select.c: In function `db__driver_open_select_cursor':
select.c:44: warning: passing arg 5 of `sqlite3_prepare' from incompatible pointer type
select.c:54: warning: passing arg 1 of `append_error' discards qualifiers from pointer target type
gcc -L/usr/X11R6/lib -L/usr/local/grasslib/lib -L/src/grass-6.1.cvs_src_snapshot_2005_09_17/
dist.powerpc-apple-darwin7.9.0/lib  -L/usr/local/pgsql/lib  -o /src/
grass-6.1.cvs_src_snapshot_2005_09_17/dist.powerpc-apple-darwin7.9.0/driver/db/sqlite
OBJ.powerpc-apple-darwin7.9.0/create_table.o OBJ.powerpc-apple-darwin7.9.0/cursor.o
OBJ.powerpc-apple-darwin7.9.0/db.o OBJ.powerpc-apple-darwin7.9.0/describe.o OBJ.powerpc-
apple-darwin7.9.0/driver.o OBJ.powerpc-apple-darwin7.9.0/error.o OBJ.powerpc-apple-
darwin7.9.0/execute.o OBJ.powerpc-apple-darwin7.9.0/fetch.o OBJ.powerpc-apple-darwin7.9.0/
index.o OBJ.powerpc-apple-darwin7.9.0/listtab.o OBJ.powerpc-apple-darwin7.9.0/main.o
OBJ.powerpc-apple-darwin7.9.0/select.o -lgrass_dbmidriver -lgrass_dbmibase  -lgrass_dbstubs -
lgrass_gis -lgrass_datetime -lz   -lintl -lgrass_datetime -lsqlite3  \
         -lz
ld: can't locate file for: -lsqlite3
make: *** [****] Error 1
-------------------------------------------- Managed by Request Tracker
