[GRASS5] [bug #3653] (grass) changing regions within ps.map
file
Hamish
hamish_nospam at yahoo.com
Mon Sep 19 20:59:53 EDT 2005
> > this bug's URL: http://intevation.de/rt/webrt?serial_num=3653
> > Subject: changing regions within ps.map file
> Just realised that ps.map actually doesn't allow placing several
> seperate maps in one run, or have I missed something ? So this would
> obviously be a precondition. Something in the lines of d.frames, but
> in ps.map...
ps.map is locked into one region for the session, but you can draw a box
around a subregion within the map by using the "region" instruction. (just
fixed in CVS a few days ago and could use some testing!)
Hamish
