[GRASS5] Problems compiling and running GRASS6.CVS
Michael Rensing michael.rensing at shaw.ca
Mon Apr 3 22:32:30 EDT 2006
Hi all, in order to try the latest GUI (among other new features), I've
compiled and run the current CVS version. On the first run through of
make, there were a lot of errors regarding failed compiles which seemed
to be related to path errors. After make install, the source code would
not start, and crashed with errors.
I ran make another couple of times, and on try 2.5 (ctrl-c in the middle
of try 2) I got a clean compile. make install now gives a running
executable.
Should I report this as a bug, or is it too soon in the development
cycle to worry about this behaviour?
Michael
