[GRASS5] Problems compiling and running GRASS6.CVS
Tue Apr 4 00:18:58 EDT 2006
Michael Rensing wrote:
> Hi all, in order to try the latest GUI (among other new features), I've
> compiled and run the current CVS version. On the first run through of
> make, there were a lot of errors regarding failed compiles which seemed
> to be related to path errors. After make install, the source code would
> not start, and crashed with errors.
> I ran make another couple of times, and on try 2.5 (ctrl-c in the middle
> of try 2) I got a clean compile. make install now gives a running
> executable.
> Should I report this as a bug, or is it too soon in the development
> cycle to worry about this behaviour?
Can you provide specific details?
