[GRASS5] Problems compiling and running GRASS6.CVS
Michael Rensing michael.rensing at shaw.ca
Tue Apr 4 22:57:48 EDT 2006
Glynn Clements wrote:
> Michael Rensing wrote:
>> Hi all, in order to try the latest GUI (among other new features), I've
>> compiled and run the current CVS version. On the first run through of
>> make, there were a lot of errors regarding failed compiles which seemed
>> to be related to path errors. After make install, the source code would
>> not start, and crashed with errors.
>> I ran make another couple of times, and on try 2.5 (ctrl-c in the middle
>> of try 2) I got a clean compile. make install now gives a running
>> executable.
>> Should I report this as a bug, or is it too soon in the development
>> cycle to worry about this behaviour?
> Can you provide specific details?
I'd have to wipe the directory and reload from CVS, but I'm just getting
started, so I don't mind doing it a couple of times. However, the output
just scrolls by on the screen so I'd have to capture it somehow and then
send you the file.
Do you want me to do that, or try something else?
Michael
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20060404/63740386/attachment.html
