[GRASS5] [bug #4262] (grass) r.prof
Sat Apr 8 00:33:31 EDT 2006
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4262
> I would like the functionality so that multiple displayed rasters (in
> the same monitor) may be profiled simultaneeously.  Ideally, graphical
> output in a window similar to d.profile would be ideal so the
> different (co-located) profiles could be viewed in addition to an
> outputted ascii file of distance versus the z values for the different
> rasters.
use r.profile or r.transect and then feed the result into d.graph,
d.linegraph, etc or externally into gnuplot, octave, xgraph, Matlab,
spreadsheet, etc....
Hamish
