[GRASS5] postscript labels for vector objects
Michael Barton
michael.barton at asu.edu
Wed Apr 19 12:02:47 EDT 2006
Lorenzo,
I think I¹ve fixed this. At least the pdf and eps output looks fine, even if
I change the postscript text overlays. I added an erase tcltk objects
command before the screen redraw. I also fixed a mislabeling problem and
added a small delay in the printing routines to (hopefully) make sure that
the eps file finishes writing before ghostscript tries to convert it to pdf.
Next, I¹m going to change the xtn menu to make it compatible with the new
GRASS Extensions Manager. You might want to see if the qgis script can
install itself via GEM, for broader compatibility.
Cheers
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
From: Lorenzo Moretti <lorenzo.moretti at bologna.enea.it>
Date: Tue, 18 Apr 2006 10:18:37 +0200
To: Michael Barton <michael.barton at asu.edu>
Cc: <grasslist at baylor.edu>
Subject: Re: [GRASS5] postscript labels for vector objects
Hi Michael
> IR17;ve just updated the GIS Manager in the cvs to add a new layer type for
> creating postscript labels for vector objects. It uses information from a
> labels file (created with v.label) to make this text. Because it creates TclTk
> text objects, it ignores v.label highlighting, background, and rotation
> options.
> Also, like the postscript text layer (renamed to clarify this), these labels
> can display on the screen or be output to a postscript device (eps, pdf, or
> printer). But they will not appear in raster ppm, jpeg, tif, or bmp output.
> I've also updated GIS Manager to conform with the new options database
> specifications, developed by Cedrick Shock. This will make formatting
> consistent across the entire gui and make it easy to change formatting across
> the entire gui.
> Michael
GREAT. This is a very useful command to insert text.
There is a problem when you make a PDF (or PS) from Print button. This is an
old problem in new gis.m.
- You create your vector - raster layers and text layers.
- You change the value inside the box more time (example text layers).
- At the end you save a PDF from Print button.
- This PDF displays any change you've made (only display the sequence of
changes): this is wrong because the file size is bigger and the
visualization is slow. This PDF have to contain only the true layers not the
history of changes. Try.
Bye
__________________________________________________________________________
|| Lorenzo Moretti e-mail: lorenzo.moretti at bologna.enea.it
||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/
|| | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
ENEA - Ente Nazionale per le Nuove Tecnologie, l'Energia e l'Ambiente
ENEA - The Italian Agency for New Technologies, Energy and the Environment
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20060419/5f20134c/attachment.html
