[GRASS5] Suggested color function names
Cedric Shock
cedricgrass at shockfamily.net
Fri Apr 21 19:58:48 EDT 2006
Hamish added a red, green, blue, alpha color structure to gis.h.
I'd like to add the following to gis.h as well:
/* RGBA_Color set values */
#define RGBA_COLOR_SET 1
#define RGBA_COLOR_UNSET 0
#define RGBA_COLOR_NONE -1
I also think it would be apropos to add some more functions that deal with
this structure instead of red, green, and blue integers. New functions means
new names. My current best idea is adding RGBA to the existing analogous
names.
We currently have
int G_str_to_color (str * name, int * red, int * green, int * blue);
int R_RGB_color(unsigned char,unsigned char,unsigned char);
int R_reset_color(unsigned char,unsigned char,unsigned char,int);
int R_reset_colors(int,int,unsigned char *,unsigned char *,unsigned char *);
How are these suggested names for new "functions":
int G_str_to_RGBA_color (str * name, RGBA_Color * color);
int R_RGBA_color(RGBA_Color * color);
int R_reset_RGBA_color(RGBA_Color * color, int);
int R_reset_colors(int,int,RGBA_Color ** colors);
The R_ functions would just use the existing protocol (no alpha support).
--Cedric
