[GRASS5] Grass and GDAL-1.3.2b1
Jachym Cepicky jachym.cepicky at centrum.cz
Tue Apr 25 07:59:17 EDT 2006
Hallo, if I underastand it well, you have to perform 3 steps:
    1) Install "somehow" gdal
    2) Install grass --with-gdal-includes=/path/to/gdal...
    3) Install gdal --with-grass=/path/to/grass/base
Good luck
Jachym
On Tue, Apr 25, 2006 at 04:45:12PM +0530, abhay menon wrote:
> hello list.
> I have been trying to install grass6.1cvs (also grass-6.0.2 too. ) with gdal
> for reading dataset AAIGrid/Arc/Info ASCII Grid large than 2gb.
> after report the same on the gdal list is was told to use gdal-1.3.2b1 for
> the same and after successfully compilation and installation I was able to
> read dataset greater than 2gb.
> but am facing problem in getting compiled version of gdal-1.3.2b1 to
> work with grass.
> after doing simple following steps in gdal-1.3.2b1
> #./configure --enable-shared --with-libtiff=internal --with-geotiff=internal
> --with-python
> # make
> # make install.
> the gdalinfo is able to read >2gb.
> but when gdal-1.3.2b1 is used(also, configured and compiled) with grass61cvs
> or grass60 (grass6.0.2 stable ed). the grass seem reports the below error
> and does nothing.
> *Error in startup script: ps.map: error while loading shared libraries:
> libgdal.so.1: cannot open shared object file: No such file or directory
>     while executing
> "exec ps.map -p"
>     (procedure "DmPrint::init" line 14)
>     invoked from within
> "DmPrint::init"
>     (procedure "main" line 34)
>     invoked from within
> "main $argc $argv"
>     (file "/usr/local/grass-6.1.cvs/etc/dm/d.m.tcl" line 1627)
> please help..!!!
> Best Regrads
> Abhay Menon
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky at gdf-hannover.de
URL:    http://gdf-hannover.de
Tel.:   +49 511-39088507
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060425/26aff9c4/attachment.bin
